Not a typical 3g alternator wiring question.
Old 03-05-2012, 08:06 PM
ITALIANO66669
ITALIANO66669's Avatar
Default Not a typical 3g alternator wiring question.
Hey yall,im looking for an opinion.I have 3g alternator so obviously i have a 4 guage power wire.It is ran in front of the radiator where the oldharness is and that seems fine and dandy.Now im getting ready to reinstalled ac in a few weeks and now i looks at it and with the radiator and ac condensor installed,the wires for the main harness and 3g alternator wire will be smashed.I dont like that because then the wire will rub and rub,then bam,issues!!!Now im thinking about rerunning the wire except this time,put the fuse on the alternator side,instead of the battery side and running the wire under the engine instead,just like the starter wires.what do yall think of that?i dont forsee an issue but maybe im missing something.i cant have that wire where it is so it has to move!thanks.
ITALIANO66669 is offline
Old 03-05-2012, 08:14 PM
mustangGT86_05
mustangGT86_05's Avatar
I routed mine along the fire wall with a circuit breaker. It was the best location for the breaker and I hooked it up to the fender solenoid. It actually routed pretty well and I put a wire loom or whatever you call them on it so it doesn't stick out like a sore thumb
mustangGT86_05 is offline
Old 03-06-2012, 01:10 AM
ITALIANO66669
the firewall isnt a bad idea actually.i know i do want my fuse closer to the alternator since theres alot more room to mount fuse as opposed to by the battery.my wire is actually hooked up to the solenoid but i just call it battery side so i guess my quote is technically incorrect.
Old 03-06-2012, 11:55 AM
mustangGT86_05
That's part of the reason why I did the firewall, but I also kinda liked how it looked better. Since I put on a strut brace I had to move my vacuum connector which left a hole to bolt the circuit breaker on. It seems to be effective, even have plenty of space from heat sources
Old 03-06-2012, 01:20 PM
Five0hFox
Five0hFox's Avatar
Any power wire running directly to the battery, needs to have a fuse close to the battery; within 12" (closer the better). If you do not and you get a short to ground on your power wire by the battery, you're going to have issues. Such as an exploding battery, possibly damaged hood, damaged paint.
Five0hFox is offline
Old 03-06-2012, 08:38 PM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
Nothing wrong with going under the engine....so long as you have enough slack but not too much....Keep in mind everything on mine is now taped up and wire loomed....
projectresto83 is offline
Old 03-07-2012, 09:16 AM
Tony71502
Tony71502's Avatar
I routed my power cable around the front of the engine bay. In front of the radiator core support, then under the air box and out near the maf right to the alternator.
Tony71502 is offline
Old 03-13-2012, 06:59 PM
ITALIANO66669
thanks for the suggestions and all yall!i know what ill be doing now thanks.
ccwebb
08-11-2015 06:47 PM
califas_1987
11-14-2010 06:22 PM
Viper/Saleen1
20
07-06-2006 03:13 PM
MAC67stang
03-30-2006 06:42 PM
Quick Reply: Not a typical 3g alternator wiring question.
