my budget build for 2013 gathering up the pieces !
Old 05-23-2013, 04:12 PM
  #61
9redfox3
9redfox3's Avatar
Was over at my friends garage hanging out with the guys we were all working on our cars in Pat's shop, Dave (RSstang) even stopped in and said hello.We worked on my brakes installed new powerslot rotors,Hawk pads,stainless steel brake lines,Caliper Sleeves Stainless Steel also all new front and back bearing with seals, the brake pads on the driver side it was worn down to the steel almost, diffidently needed to be changed. We had some problems bleeding the brakes but we finally figured it out and got the pedal nice and firm again ! Doing the rear brake shoes next week, Had a good time ! Here's a couple pics..
Next thing for the "RedFox " this fall is King Cobra 10.5" Stage 2 Clutch Kit Package !
So anyway my wife been saying she now wants a mustang so I traded in her Altima and bought her a 2011 v6 auto 305 hp mustang she's happy! Here's a pic of the two pony's nose to nose.....
9redfox3 is offline
Old 06-03-2013, 12:47 PM
  #62
StangLife
Former Sponsor
StangLife's Avatar
nice garage!
StangLife is offline
Old 07-23-2013, 06:15 PM
  #63
9redfox3
9redfox3's Avatar
I bought today a Ford Racing Replacement Flywheel - 6 Bolt 50 oz for the fox starting to gather up the pieces for the new clutch assembly going in this fall ! Here's the clutch kit i'm putting in minus the clutch cable going with a Maximum Motorsports High Performance Clutch Cable !
http://www.uprproducts.com/mustang-k...l-package.html
9redfox3 is offline
Old 07-29-2013, 07:24 PM
  #64
9redfox3
9redfox3's Avatar
This was at my door step today ! Buying the clutch cable next...
9redfox3 is offline
Old 09-30-2013, 06:31 PM
  #65
9redfox3
9redfox3's Avatar
I got the MM clutch cable now just waiting to put the new parts in can't wait,this car has needed a clutch and new cable since the day I bought it ! Plus I just ordered four new Drake Muscle Cars Wheel Center Cap With Tri-Bar Emblem 1991-1993 argent silver for the fox having my factory rims all re: powder coated this winter and matching the color to these center caps,the old factory on the right and new on the left and decided it was time for some classic plates this fox isn't going no where anytime soon .....
9redfox3 is offline
Old 10-01-2013, 11:47 AM
  #66
88 orangepeel notch
88 orangepeel notch's Avatar
Great thread, congrats on all your hard work and money spent. It's a good feeling doing as much as you can yourself. Car looks great.
88 orangepeel notch is offline
Old 10-23-2013, 02:56 PM
  #67
9redfox3
9redfox3's Avatar
^ Thanks Decided while we were under there this winter putting in the new clutch kit to install new upper and lower Steeda control arms,the original factory ones need to be replace on this stang ! Here's a pic got them today and a little info on them...
http://www.steeda.com/blog/2012/01/t...-control-arms/
9redfox3 is offline
Old 04-09-2014, 08:56 PM
  #68
9redfox3
9redfox3's Avatar
Today Installed a new cobra clutch kit assembly with new MM clutch cable and firewall adjuster,aluminum quadrant.I had another flywheel to install which was good because the one on the car had a broken tooth gear.Also checked the rear main seal that turned out to be still in good shape. The leak was at the oil pan dripping down in the bell housing he sealed that up, we'll see ! The clutch feels better to me I like where it releases now and the pedal feels not has stiff. I like the firewall adjuster makes it easy enough to adjust if needed and not having to go under the car ! The tranny parts where pretty dirty from not being off the car in 46k miles but a little bit a brake cleaner took care of that ! Thanks "Shifter Lou" for all your help ! Here's some pics ....
Parts cleaned up and installed cobra clutch kit !
This fall the new rear Steeda control arms going in and this winter the stock rims are getting powder coated !
9redfox3 is offline
Old 10-11-2014, 03:28 AM
  #69
9redfox3
9redfox3's Avatar
Getting the car dynoed on monday for the first time any GUESSES of what kind of RWHP she will make ? Here's my list of mods !
Bored 40 over
Gt 40 heads (F3ZE) rebuilt
original 93 cobra intakes
1.7 crane rockers
255 walbro fuel pump
accufab 70mm tb
75mm 19lbs maf
bbk ceramic shorty headers
h-pipe high flow cats
Aluminum drive shaft
stock cam & 19lb injectors
underdrive crank pulley
Will show the results on monday !
9redfox3 is offline
Old 10-12-2014, 07:30 PM
  #70
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Bored 40 over
1.7 crane rockers
accufab 70mm tb
75mm 19lbs maf
probably less than your wifes v-sixer.....lol seriously, depending on the dyno, if it's a dyno jet, 250-260.......I did a gt-40 intake, gt-40 heads and tfs 1 cam for a guy and his put out 266 on a dyno jet.....so you might be a tad under that with stock cam.
mjr46 is offline
Quick Reply: my budget build for 2013 gathering up the pieces !
