My new build direction: Any Suggstions
Old 07-22-2013, 08:34 PM
Ineedmorespeed
Ineedmorespeed's Avatar
Default My new build direction: Any Suggstions
Plans for my 95 Mustang GT 5 Speed
Already has -
Aftermarket BBK Headers and off road H pipe
Upgraded Ignition - Distribtor/Control Module/Coil/Wires
Cold Air Intake
My Next 3 steps
Step 1 - Aftermarket rear control arms
Detroit tru-trac Diff
Most likely 3.73 gears(havent decided yet)
New clutch (thinking stage 2 not sure yet)
Step 2 - Gt40 upper & lower intake
70/75mm Throttle Body
70/75mm Mass air
Not sure if i need to upgrade to 24# injectors
Step 3 - Gt40 heads
havent decided what cam yet
Would like to hear suggestions on if this is a good way to go, or if theres something that could make it a little better.
Could anyone also guesstimate HP?
Ineedmorespeed is offline
Old 07-22-2013, 08:57 PM
Duncan_GT
Duncan_GT's Avatar
70mm throttle body, 70mm maf, yes upgrade to 24lb injectors. I would guess 250-260 horsepower. Why are you upgrading the diff? Are you racing?
Duncan_GT is offline
Old 07-22-2013, 09:07 PM
89fiveeight
89fiveeight's Avatar
Im just glad there's someone else paying attention to their suspension instead of just building a motor and wondering why their 20 year old car wont run 12's
89fiveeight is offline
Old 07-22-2013, 09:17 PM
Ineedmorespeed
Yea definatly, when I do the rear end going to go almost all aftermarket new in the rear and after the motor upgrades I going new suspension upfront as well..
Old 07-22-2013, 09:22 PM
Ineedmorespeed
@ Duncan Im not racing but with the miles and stock rear end i want an upgrade with the power i wanna put through it. Plus Just had a buddy that just blew out the diff in his. So Since I want to change the gears I planed on just Beefing up the rear end.
Old 07-22-2013, 10:34 PM
Duncan_GT
Duncan_GT's Avatar
I gotcha. Check the general discussion for the 5.0's, I had a thread about an 8.8 build
Old 07-24-2013, 06:04 PM
Ineedmorespeed
I just picked up my gears set of 3.73 cant wait to put them in tomorrow...
I know my speedo going to be off for now until i replace my trans speed gear..
Does anyone know about how far it will be off??
Old 07-25-2013, 09:24 PM
UPRSharad
Former Sponsor
UPRSharad's Avatar
Decent plan. I'd recommend UPR suspension (including torque box reinforcements while your control arms are out) and I'd also install the intake manifold at the same time as the cylinder heads. Just my two cents.
UPRSharad is offline
Old 07-25-2013, 10:59 PM
Ineedmorespeed
@UPR I was going to look into some more suspension upgrades as I go along.. I was only planning on changing the intake first then the heads after awhile to give me a lil bit more first without breaking my wallet.. but who knows might wait and do it all at once just depends on money...
Old 07-26-2013, 10:28 PM
UPRSharad
Former Sponsor
UPRSharad's Avatar
I understand what you mean there. I only recommended doing them at the same time because you don't get the true gains from the intake until you match it with a good heads/cam/TB/MAF combo. Also, you'll be doing the same job (intake manifold installation) twice if you do the intake, and then the heads.
But I fully understand your point about saving in between.
svfetter
10-05-2015 11:39 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
the5
09-19-2015 06:13 PM
2015Ecoboost
09-17-2015 01:48 PM
rksnow1
09-14-2015 08:46 PM
Quick Reply: My new build direction: Any Suggstions
