Steeda Firewall Clutch Adjuster
Old 05-05-2014, 10:51 PM
2000AZ5.0GT
2000AZ5.0GT's Avatar
Default Steeda Firewall Clutch Adjuster
Hi Everyone.
So, I have an 88 Mustang GT, bone stock, and I just replaced the clutch. The pedal grabs about 0.5" off the floor, so I ordered the Steeda Firewall Clutch Adjuster, without reading that apparently it "Must be used with the Steeda Double Hook Quadrant...".
I'm not seeing why it would be required (other than for strength), and wasn't able to order it before now.
I'm wondering if anyone ever installed the firewall clutch adjuster without their double hook quadrant? It looks virtually identical to every other adjuster that I can find, so I'm wondering what the heck is so different about it that I need to use their quadrant, and have them installed at the same time.
Now, the car is currently at the shop (the clutch cable, which was new, failed as I was driving, and had to have it towed back), so while I have the adjuster in hand, I don't have the quadrant. I'm wondering if I can have them just install the adjuster, and the next time I have a chance, install the quadrant myself?
Thanks in advance for any light anyone can shed on the topic.
2000AZ5.0GT is offline
Old 05-13-2014, 10:27 AM
64bit
64bit's Avatar
Absolutely does not need to be used with THEIR quadrant. it just shouldn't be used with the stock quadrant.
I personally suggest the steeda quick release. Do not buy multi-hook quadrants.
64bit is offline
Old 05-13-2014, 07:59 PM
tj@steeda's Avatar
What is your email address? I don't have the specifics to this question ... but I can put you in touch with Matt or Don who are Fox Body experts.
Send me an email to tim@steeda.com & I will ensure they follow up with you and help with your question.
Best Regards,
TJ
tj@steeda is offline
Thunderball
15
11-22-2015 11:49 PM
Florida Regional Chapter
09-30-2015 08:04 PM
winner99
09-30-2015 07:04 PM
junior04
09-28-2015 10:53 AM
09-24-2015 09:18 PM
Quick Reply: Steeda Firewall Clutch Adjuster
