trans fluid change (is royal purple worth the $)
Old 05-18-2014, 09:43 PM
95greengt
95greengt's Avatar
Default trans fluid change (is royal purple worth the $)
Ok so I am about to change the fluid and filter in my 95 gt. Is it worth the extra $$ to use royal purple? If there is actual gain from it I have no issue spending the money but I could use that money on something else.
What fluid are you using?
95greengt is offline
Old 05-19-2014, 04:20 AM
5.0Yeah!
5.0Yeah!'s Avatar
Yes. As someone who has used this in several cars, it definitely seems to cut friction and chatter at higher RPMs.
5.0Yeah! is offline
Old 05-19-2014, 07:01 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
pure waste of money.........all royal purple is, is a synthetic fluid with purple dye, I'd choose amsoil over it any day(better detergent packages and friction modifiers)......if your gt is an auto equipped car, then changing the trans fluid in it with royal purple is truly a pure waste as all you can do is drop and change what fluid is in the pan, you still have what's left in the torque convertor, lines and internals in trans full of fluid, to do it right a trans flush is what you need, most flush machines will use 12-16 quarts.........still wanna use royal purple?? If you just do what's in the pan, it's just gonna be mixing what's in there....kinda like playing in a mud puddle and dumping fresh water into it, hoping it'll be clear afterwards, IMO, just use a quality dex3/mercon fluid if just dropping the pan.
mjr46 is offline
Old 05-19-2014, 08:49 PM
95greengt
95greengt's Avatar
MJR... That is pretty well what I was thinking. I plan on draining the converter but I haven't decided yet if I want to flush the cooler and lines yet.
Old 05-26-2014, 10:01 AM
eb2gt
eb2gt's Avatar
excellent advice, I sell this stuff in the store. Slow moving product. Stay with the basics and save your money.
eb2gt is offline
Old 06-01-2014, 12:46 AM
tinman
tinman's Avatar
Total waste of money.
tinman is offline
Old 06-03-2014, 11:25 AM
uedlose
uedlose's Avatar
I run John Deer Hygaurd in all my auto trans. or Case Hytran. Everything from AODEs to C4s works great.
uedlose is offline
Old 06-03-2014, 03:01 PM
mjr46
mjr46's Avatar
so that is the secret fluid you have been using!!!!!!!
mjr46 is offline
Old 06-04-2014, 09:54 AM
uedlose
uedlose's Avatar
LOL yes sir. Good stuff for sure. Got just a few people laughing at me about it but it works well. Also been done before I started doing it years ago. Drops trans heat no Friction modifiers so when it changes gear it hits with less slippage. And the shear strength is very high. The one thing I dont like about it, is it dont burn real easy good and bad due to it not changing colors if it overheats. So you have to pay attention to the trans to tell you when you are in trouble or have a trans temp. gauge even better. But that is more when you are racing and running back to back runs. Yes, it works very well in a D/D also. Works very well when running a trans. break so far, but we are still looking at that on one of my new builds for a customers C4. I also used it in my sons AODE and it worked great in it. it use to shudder when the converter locked up it fixed that also for years, but it did come back and now will need a rebuild but the car has over 200k on it. I am sure.
uedlose is offline
Old 06-13-2014, 12:17 PM
bdraisey
bdraisey's Avatar
I just posted yesterday asking this same question. The previous owner of my mustang insists that I continue using Royal purple.. Which I have and have no problem with it, but wondered what the real difference is. [IMG]Are you specifically looking for that year, model, make of mustang? [/IMG]
bdraisey is offline
2007StangV6
01-28-2016 06:09 PM
97SN95GT
09-13-2015 09:45 PM
Pyrate Dave
09-10-2015 07:30 PM
IronRaptor
09-09-2015 08:10 AM
Quick Reply: trans fluid change (is royal purple worth the $)
