Hanging revs
Old 03-02-2015, 06:24 PM
bluovalguy
bluovalguy's Avatar
Default Hanging revs
Had new clutch installed after clutch cable broke in 95 gt. Got it back and noticed when I shift, the revs hang or sometimes even increase. If I put the car in neutral and coast to a stop, the rpm's will hang between 1200-1500 rpm's until the car comes to a complete stop.
Searched and most people said IAC so I changed that two days ago. Same problem is still occurring. Doesn't really seem like the new part changed anything.
Would a vacuum leak cause the same sort of issues? Or any other ideas? Many thanks for any help.
bluovalguy is offline
Old 03-09-2015, 05:50 AM
64bit
64bit's Avatar
IAC never is, and never was your problem. The people who say so, have no freaking clue.
Have you ONLY replaced the clutch and cable? Did you put an aftermarket TB on?
Typically the hanging idle is caused by a vac leak in the 94-95 cars... although the installation and improper adjustment of an aftermarket throttle body, can cause the same issues.
64bit is offline
Old 03-09-2015, 10:18 AM
bluovalguy
bluovalguy's Avatar
Thanks for the reply.
When I bought it, the PO had put a bbk 70mm throttle body on it and a bbk 90mm MAF.
Old 03-10-2015, 10:49 AM
eb2gt
eb2gt's Avatar
FYI, I have had throttle lever/cable stick on me after sitting for a month etc. and do the same thing yours is doing. Lubed a little with oil and it quit.
eb2gt is offline
Nick Oliver
10-17-2018 04:22 AM
firehorse02
11-16-2015 11:28 AM
BeatnikFink
10-01-2015 08:00 PM
Florida Regional Chapter
09-30-2015 08:04 PM
wraith777
09-28-2015 10:49 AM
Quick Reply: Hanging revs
