idle issues on 1989 5.0
Old 03-31-2015, 09:35 PM
Jayraud
Jayraud's Avatar
Default idle issues on 1989 5.0
I recently installed a different engine (1986) Gt block, gt40 heads, bored .030 over with stage 1 trick flow cam a9p ecu. The difference is, I put this into my 1989 f-150 4x4. Now I can't get it to idle smooth at all. Also, once I put it in drive and hold the brake, it surges forward with the idle. I can't find anything wrong. Any ideas would help me out. Thanks
Jayraud is offline
Old 04-01-2015, 11:24 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
was your truck mass air equipped before?? and if not and a proper mass air conversion was not done that may be the issue, you can't just plug a mass air ecm into a Speed density harness and expect it to work.....or is the truck speed density currently and you figured plugging a mass air ecm would work??...........you have by far have not provided enough info for anyone here to properly guess what your issue could be since you are doing a swap/conversion between different models
mjr46 is offline
Old 04-01-2015, 06:46 PM
Jayraud
Jayraud's Avatar
Sorry for the lack of info. It's been quite a project to undertake. I did do the maf conversion. When I first start up the truck cold. It cranks over and revs about 3000 rpm (no rpm tach), then it dies. I have to keep cranking it over 3-4 times giving it gas for it to actually idle. Once it idles (not great), I put the truck into drive, while holding the brake, the truck wants to surge forward and the idle slightly revs with the surging. Any ideas?
Jayraud is offline
Old 04-01-2015, 08:00 PM
mjr46
mjr46's Avatar
check for vaccum leaks and make sure that your map sensor is no still plugged into a vaccum source....it becomes a BAP on maf vehicles
mjr46 is offline
Old 04-01-2015, 08:29 PM
Jayraud
Jayraud's Avatar
Map sensor has been changed. I ran a code reader on it and it says my throttle position sensor signal is out of range. I've been watching several videos on setting a TPS and understand the voltage on the green wire should be from .75-.95 volts. I am getting 60-70 volts...brand new tps bad??? something is WAY wrong...
Jayraud is offline
Old 04-01-2015, 08:53 PM
bluebeastsrt
bluebeastsrt's Avatar
Check for vacuum leaks before anything else. Elimanate the likely stuff before you start chasing electrical gremlins.
bluebeastsrt is offline
Old 04-02-2015, 11:00 AM
mjr46
mjr46's Avatar
up to 1.0 vdc is acceptable
mjr46 is offline
Old 04-03-2015, 01:48 PM
Jayraud
Jayraud's Avatar
I have checked vacuum leaks multiple times. I had to plug the majority of the ports in the intake.
Jayraud is offline
Granatelli Sales
03-25-2016 08:01 PM
2007StangV6
01-28-2016 06:09 PM
Granatelli Sales
12-27-2015 06:28 PM
JT76
09-20-2015 11:32 AM
Emblazoned
09-03-2015 10:45 PM
Quick Reply: idle issues on 1989 5.0
