91 vert 347 build question/recommendations
Old 04-26-2015, 09:58 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Originally Posted by bluebeastsrt
That's pretty impressive for a full weight car. A couple pounds her, a couple pounds there and it'll be hittin 10.5s on the slicks.
yea.....'bout that time is when it'll split in two....I'd rather be in your shoes with what you have !!
mjr46 is offline
Old 04-27-2015, 06:29 PM
Puff0725
Puff0725's Avatar
Car runs great man! Thanks for all the input thus far! As much fun as the 363 would be my "financial advisor" is convinced I NEED a dart block right now haha! Looks like that's been ruled out of the equation... For now lol! I'm looking at a kit through late model restoration right now that seems pretty decent. http://www.latemodelrestoration.com/...5-Flat-Top-Pis
Thoughts?
Puff0725 is offline
Old 04-27-2015, 07:13 PM
bluebeastsrt
bluebeastsrt's Avatar
Looks like a nice kit but it's the stock block that's in danger once you exceeded 500 wheel horse power. MJRs advice is spot on. Keep the revs below 6500 and have your tune perfect and the motor can last a while. Even if you only make 375-400whp the car will be a beast on the street.
bluebeastsrt is offline
Old 04-28-2015, 06:43 AM
mjr46
mjr46's Avatar
Thoughts?
that's fine.......however expect your rwhp depending on what h/c/i is chosen and supporting mods you have to deliver in the range of 350 rwhp to 375 rwhp on average.
mjr46 is offline
Old 05-03-2015, 12:54 AM
tinman
tinman's Avatar
Ok, I use an early 302 truck block (1969) a 3.4 stroke crank, that early block took a .060 overbore fine. I use Eddy VicJr. heads and intake with a Quickfuel 750 carb. I use a solid roller of 142@.050 cam, lift .630ish. Use a C-4 trans with a 4500 convertor, 4.30 gears.
Car is 2775 with me onboard.
I've run 10.85 many times as well as 125+ lots of times.
This is in dry desert air in air density of 3600-4000'.
Sea level like most people live at or near I think the car would run 10.50's.
There are NO custom built parts on the car and the heads are unported.
In fact I think every part on the car was out for sale 20+ years ago.....
tinman is offline
Old 05-06-2015, 01:20 AM
tinman
tinman's Avatar
BTW, stock suspension is used 100% and it's operated on pump gas......
tinman is offline
robcy
Suspension
10-27-2015 11:14 PM
svfetter
10-05-2015 11:39 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
Brett Ludlow
09-23-2015 06:59 AM
EASTIDEE123
09-15-2015 11:08 AM
Quick Reply: 91 vert 347 build question/recommendations
