Chassis/Suspension Stiffening
When I changed my control arms, the bolts holding the lower arm to the axle were by far the worst. After wrestling them out, I took them to a local Fastenal, where they matched up some new ones for me.
I don't remember the size or length, but they were metric and I made sure to get heavy-grade hardware.
I'd honestly just feel better replacing the bolts from 1988 with some new ones since I'm taking them out anyways.
Does anyone see a need for upgrading front and rear sway bars with some beefier ones, or would that be overkill with the already listed mods?
Do you remember how much the bolts were? That seems to be the most likely option long as they don't want an arm and leg.
Yeah, I'm pretty sure the stock bolts used 18mm tools as well.
I don't recall the exact cost of the bolts. I just checked my records folder, but it looks like I didn't save that receipt.
From what I remember off the top of my head, the bolts weren't terribly expensive, like some dealership bolts or ARP kits. I want to say that I paid somewhere in the neighborhood of five bucks per bolt (I could be wrong). The UCA bolts looked good enough to re-use, so I only bought enough (4) for the LCAs, as they were pretty bad.
EDIT: I don't know why they didn't get thrown out, but I still had the old bolts sitting on my workbench! They are class 10.9 metric, and the shank seems to be 12mm. Length is 4 inches, or 4.5 overall if you count the head.
09-10-2015 08:39 PM
09-08-2015 11:50 AM
09-02-2015 07:54 AM
