V8 5.0 HO - From Argentina
Old 02-01-2016, 01:42 PM
facusessa
facusessa's Avatar
Default V8 5.0 HO - From Argentina
Hello how are you? My name is Facundo, I'm from Argentina. First of all sorry for my English, I am writing through a translator.
Buy last year 5.0 HO V8. This one injection to carburetor change because purchase only the block with the cylinder heads.
My question is which means "cam rollers" ??? . the camshaft is to roll ??
The hydraulic lifters are or roller in this model?
Thank you very much to all
facusessa is offline
Old 02-02-2016, 06:52 AM
88 orangepeel notch
88 orangepeel notch's Avatar
If I'm understanding you correctly, you have a roller lifter block. If it's a true H.O. motor.
88 orangepeel notch is offline
Old 02-02-2016, 10:53 AM
facusessa
facusessa's Avatar
Ok,
then the camshaft is rollers
roller lifters too?
Old 02-02-2016, 02:57 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
it's a roller cam and has roller lifters...there is correct English terminology for what you have ...
mjr46 is offline
Old 02-03-2016, 07:17 AM
facusessa
facusessa's Avatar
Thank you very much , in Argentina there is not much information on this type of engines because few are imported.
And the translator does not work well with technical English
Old 02-05-2016, 07:50 AM
mjr46
mjr46's Avatar
Entonces porque no hablamos en castellano con el uno y el otro?
mjr46 is offline
Old 02-05-2016, 11:57 PM
65Raven65
65Raven65's Avatar
If I am understanding you correctly, you are asking if the 5.0 is a roller set up?
In other words, there are rollers on bearings at the ends of the lifters where they meet the camshaft. The lifters are also hydraulic, they collapse under certain pressure.
A regular hydraulic cam does not have the rollers on the ends.
Yes, the 5.0 is a roller engine. It even has rollers on the ends of the rocker arms, but is not considered full roller because the rocker fulcrum does not have roller bearings.
Does this help, facusessa?
65Raven65 is offline
Old 02-10-2016, 07:24 AM
facusessa
facusessa's Avatar
Que bueno encontrar a alguien que hable castellano. Trate de estudiar ingles pero no tuve buenos resultados
Yo compre ese motor pero la descripcion decia "roller Cam" y no sabia si eran botadores a rodillos o hidraulicos. Ya que los balancines no son a rodillo pero no tienen para regular la luz de valvulas.
Si son balancines a rodillo no deberia poder ajustar la luz de valvulas?
Old 02-10-2016, 07:28 AM
facusessa
facusessa's Avatar
So if I understand correctly , lifters are roller ?
Old 02-15-2016, 06:51 PM
mjr46
mjr46's Avatar
Yo vivi en Chile por dos anos, asi que puedo hablar lo que ustedes llaman Castellano..........pero hace veinte anos que me fui de alla. El "camshaft" o mejor dicho, el árbol de levas, usa botadores a rodillos. Aqui esta una foto de un botador a rodillo por un motor de 302 :
El rodillo anda sobre el lóbulo del árbol de levas y otra cosa sobre todo es que los botadores a rodillos son hidraulicos, esto quiere decir que no tienes que ajustar las valvulas. Sin embargo, tienes que ajustar la precarga de los botadores para que no hagan ruido. Espero que te lo haya explicado de una manera en que lo puedes comprender. Una de las cosas que me faltan, son las palabras tecnicas de Espanol.
mjr46 is offline
Quick Reply: V8 5.0 HO - From Argentina
