wheel hop
Old 02-28-2015, 02:02 PM
regierrick
regierrick's Avatar
Default wheel hop
hey guy's, I'm a noob here and just got a 2015 GT performance pack, brembos,track loc,373s, and the wicked wheel hop.are there any fixes for this or ideas. thanks for yall's ideas maybe someone out there can help
regierrick is offline
Old 02-28-2015, 03:44 PM
AK_Kayaker
AK_Kayaker's Avatar
Oh there are people working on it, Steeda has $135 bushing kit, that they say reduces hop, and increases rear traction.
I think you should post a vid, so we can all see how bad your hop is, it will help everyone in the long run, to see how hop varies from owner to owner.
AK_Kayaker is offline
Old 02-28-2015, 04:28 PM
regierrick
regierrick's Avatar
i'll try to get a vid . but in the meantime I can do a burnout on dry concrete, my driveway. it will leave aproxx 20 to 30 black marks about 4" long with about 4" long spaces between, leaving a light I can feel it so I don't do it much.
Old 02-28-2015, 04:29 PM
regierrick
regierrick's Avatar
even rolling on the throttle thru the gears it hops
Old 03-01-2015, 10:01 AM
topangler25
topangler25's Avatar
I get some pretty wicked hop as well. All the way through 3rd. After that the tires do not break loose.
topangler25 is offline
Old 03-01-2015, 10:04 AM
topangler25
I think the packs that Ford has put together for the King Cobra will help quite a bit. should be available soon from Ford Racing
https://media.ford.com/content/fordm...5-ford-mu.html
Old 03-01-2015, 10:52 AM
Norm Peterson
Norm Peterson's Avatar
I'm thinking that the [front] bushings in the rear LCAs are mainly responsible for allowing hop. The best solution is not likely to be as simple as casting something up in polyurethane and calling it done . . .
Norm
Last edited by Norm Peterson; 03-01-2015 at 10:53 AM. Reason: still having to delete blank lines inserted by ignorant forum software. Grrrr. Is this ever going to get fixed?
Norm Peterson is offline
Old 03-01-2015, 03:55 PM
AK_Kayaker
AK_Kayaker's Avatar
Norm
Does the new IRS even have anything like the old LCA, the Steeda kit replaces the subframe mounting bushings.
Old 03-01-2015, 06:30 PM
Norm Peterson
Not like a S197/SN95/Fox rear LCA, no. The LCA in most any IRS is laterally oriented like a front suspension LCA.
Norm
Old 03-03-2015, 10:06 AM
moosestang
moosestang's Avatar
Ah, the awesomeness that is IRS. A solid rear axle with aftermarket control arms will fix you right up.
moosestang is offline
Quick Reply: wheel hop
