Turning Traction OFF disables 1-4 shift!!
So I found out tonight that turning off the traction control on the 2011 GT also disables the 1st-4th skip shift assistance. It was really annoying b/c going from 1st to 2nd feels lumpy and forced, but when I turn off the TCS it feels nice and crisp. You still get the message but the actual physical intervention is gone. I guess I'll be doing a lot more donuts and drifting around more turns now.
Something like "Skip shift on for fuel econ." Flashes so quickly, don't have time to read it. Usually just a flash out of the corner of my eye on the tachometer message centre. Actually, it's very benign on the Mustang compared to my earlier Camaros. If you're dawdling away from the light and it guides you into 4th, then you were not in a hurry anyway. The Camaros would lock you out of 2nd and leave you groping around in neutral trying to find fourth gear. By the time you found it, the skip-shift feature would have disappeared anyway and you would then select 2nd. Meanwhile, you would have people all over your rear bumper! Real bummer. People used that resister by-pass thingy to get rid of it. Not really bothersome on the 5.0.
SandMan123:
I would not get in the habit of arbitrarily turning the T/C off (except at the track) as some day you may need it and it won't be there to save your bacon. I read somewhere that some bozos actually connect it up backward so it's not on during start and has to be selected on with the switch at the driver's whim. Bad idea.
Also, for the track only I hope, holding the T/C button down for 5 seconds with the brake on disables the T/C (light on the speedometer) and the stability system (message on the tach).
Cheers.
SandMan123:
Cheers.
tl;dr if you can't drive a car without TC on, maybe you shouldn't be driving a car.
