5.0L V8 Technical Discussions Any questions about the 'Coyote' engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
View Poll Results: multiple choice.. Tick tick tick? What do you think VOTE
it's normal.. You are now the proud owner of a timex
23.08%
a ticking engine? whats normal about that?
7.69%
my 2011..2012 ticks too
30.77%
My 2011.. 2012 has never ticked
53.85%
Multiple Choice Poll. Voters: 13. You may not vote on this poll
Is the tick normal or is that BS
Old 07-16-2011, 01:40 PM
Sleeper5.0
Sleeper5.0's Avatar
Originally Posted by Blacksmoke
Did you say there WAS a TSB on this?
If so and you have the symptoms the NO it is not normal.
In that case take it to another dealership that gives a flip about it's customers.
Get them to perform the service procedure that the TSB says to do.
Dont fall for them brushing you off man. DONT do it.
And if you could post me a link for the TSB. I'd like to read it.
No TSB. Not yet. Until there is or if there is, you can forget a dealer fixing the issue.. Unless by some miracle one puts forth effort...
The service manager said the more complaints ford gets from it, the more likely they will come up with a fix down the road...
So best bet is to watch the forums for when the TSB come out if it come out.. Kill as many Camaros while you wait..
Sleeper5.0 is offline
Old 07-16-2011, 04:06 PM
cidsamuth
cidsamuth's Avatar
Originally Posted by pdonket
If I have the same tick you're talking about, then it isn't the ticking that happens after you turn it off coming from the exhaust cooling. I've only noticed mine at idle since it's fairly quiet, mostly when I'm out of the car, you can hear it coming from under the car in my case, usually pretty regular and hardly audible for me unless you're in a place where the sound can echo back like the garage.
That sounds like this tick. Sometimes Ford tells folks it's normal, other times not:
http://www.youtube.com/watch?v=4vO65gQUNYg
I think the OP was talking about this tick:
http://www.youtube.com/watch?v=jB-F409uegg
cidsamuth is offline
Old 07-18-2011, 11:34 AM
Nuke
Nuke's Avatar
The 4.6L have whats considered by Ford to be normal ticking of the fuel injectors and on some cars, folks consider it to be extreme. I don't know if the 5.0 has a similar condition... no, wait. "Condition" would imply a problem.... hmmmmm...
Nuke is offline
Old 03-25-2012, 12:06 AM
2007VortechRoush
2007VortechRoush's Avatar
Default I'm having the same ticking sound has anyone figured out the cause.
has anyone figured out the cause of this tick, I've got the exact same one.
2007VortechRoush is offline
Old 03-25-2012, 09:39 AM
Maraman
Maraman's Avatar
I have never had a sound similar to that with my 2012. I have 11,500 miles. Go to a different dealer.
Maraman is offline
Old 03-26-2012, 08:49 AM
2007VortechRoush
I've figured out a short term cure that works 100 percent on removing the sound with a special blend.
Old 03-26-2012, 10:34 AM
Mishri
Mish-ogynist
Mishri's Avatar
you have the same exact tick in your 2007 with a rousch stage 2?
it's your injectors, it's normal.
with the OP you notice he had to have the camera down in the engine bay to hear it and you couldn't hear it at all from the cabin.. you guys would need to listen to your engine idle with the hood up and head in the engine bay to hear it.
Mishri is offline
Old 03-26-2012, 03:50 PM
Jiggy_One
Jiggy_One's Avatar
First video is completely normal. Second one is NOT normal./
Jiggy_One is offline
lincolnshibuya
12-08-2015 04:37 PM
breaking
10-02-2015 01:27 PM
guitarman376
09-30-2015 05:54 PM
Sixer4Life
09-28-2015 07:05 AM
Shadow7874
09-24-2015 09:06 PM
Quick Reply: Is the tick normal or is that BS
