5.0L V8 Technical Discussions Any questions about the 'Coyote' engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
FRPP ProCal and gears
Old 08-28-2012, 09:08 PM
mustangergt
mustangergt's Avatar
Default FRPP ProCal and gears
I have a 2013 GT/CS automatic stock so it has 3:15 gears.
Only thing I have added was Borla S-type. Best mufflers in my opinion.
Anyway, my question.
I am reluctant to just go all out and install a CAI and tune , from AM or C&L, because of warranty reasons.
So if I had dealer install the FRPP ProCal tuner, to make my car feel like I just added a bunch of power, similiar to doing a custom tuner, would installing gears at the same time help and if so what would be the best choice for the auto,,3:31, 3:55, 3;73
Thanks
mustangergt is offline
Old 08-28-2012, 09:19 PM
Warrio17
Warrio17's Avatar
Go with the 3.73 won't be disappointed!! Best all around setup
Warrio17 is offline
Old 08-28-2012, 11:34 PM
AZAlloy
AZAlloy's Avatar
You need to drive them all! I had 3.31 in my 07 GT, 3.55 in my 04 Cobra, and 3.73 in my current 5.0. I can't stand the tall gears for everyday driving. A shift a ton and first gear is about worthless. IMHO, I like 3.55s. But to each their own. Try them at all the dealer.
Also, the CAI and tuner won't give you warranty problems unless the parts were a direct cause of the issues. IE A CAI won't give you a problem if your radio stops working. I was actually talking to my service center about this today.
AZAlloy is offline
Old 08-29-2012, 12:37 AM
kingGingy5.0
kingGingy5.0's Avatar
there is a quite a few people with 4.10s in the automatic '10-'13 on this forum....I havent seen anything bad about em...they all seem to run good 1/4 mile times too.
kingGingy5.0 is offline
Old 08-29-2012, 04:01 PM
scottmach
scottmach's Avatar
What's your idea of "good". The fastest N/A autos are running 3.31's. 4.10's will have you shifting into 4th before crossing the line.
scottmach is offline
Old 08-29-2012, 04:10 PM
scottmach
scottmach's Avatar
Thanks
Without a tune the dealer cannot change gears with the autos because it was not an option with anything but 3.15's. That includes the Procal. The question is what are your plans with the car? A tune would make you feel differently about a gear change. My car with the stock 3.15's will roast the tires if I don't feather the throttle. These transmissions have 4.17's for first gears thus making the rears closer to 3.55's-3.73's.
Old 08-31-2012, 09:32 AM
ho50ca
ho50ca's Avatar
Agreed. The Procal makes so much torque down low compared to stock you're going to love it, even with the soft rear gears.
ho50ca is offline
Old 09-06-2012, 06:05 PM
mustangergt
[QUOTE=scottmach;8035322]Without a tune the dealer cannot change gears with the autos because it was not an option with anything but 3.15's. That includes the Procal.
That is actually not true with the Procal. I just called Ford Racing tech line today and he said I could change the gears and use the Procal to adjust for the gears. And he said if I want more feel of power to go with 3:73's.
I had a 2011 V6 with stock 2:73's and got 31 mpg.
After CAI, tune from AM, BBK long tube, X pipe and Ford Racing 3:73's
my mpg dropped to 24.5 at best on a 1100 mile trip one way.
So if I did 3:73 with 2013 GT auto, my mpg would probably be even worse.
I will be install Procal on 9-14. at dealer.
Old 09-06-2012, 06:22 PM
scottmach
scottmach's Avatar
Sorry but the Ford racing Tech person you spoke to is an idiot. You cannot adjust for any other gears on the autos with the Procal because that is the only gear that was offered in them.
Old 09-06-2012, 08:02 PM
mustangergt
I have asked them twice. Tomorrow I will call again and ask and even tell them I heard that I cannot adjust for a gear change with the Procal in my 2013 automatic. I will report back what he, the idiot, says again.
I will also call my dealer tomorrow and tell them I want to also do a gear change and see what they say.
I do not know what gear to change to: 3:31, 3:55, 3:373
Quick Reply: FRPP ProCal and gears
