5.0L V8 Technical Discussions Any questions about the 'Coyote' engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
2012 5.0 randomly won't start
Old 10-02-2012, 04:25 PM
Logan Maples
Logan Maples's Avatar
Default 2012 5.0 randomly won't start
so I have a 2012 5.0 mods include boss 302 intake manifold, cia, xpipe and exhaust, Bama tune.. Has about 8,500 miles on it. Last week my girl killed it leaving apartments then it wouldn't start, acted like the clutch wasn't pushed in all the way. It didn't throw any codes or anything wouldn't turn over at all. So we pushed started it didn't have any problems for a couple days then did the same thing a couple times since then. Have an appointment with the dealer tomorrow. Think any of my mods will effect this issue or the warrentyand has anybody had this same problem.
Logan Maples is offline
Old 10-02-2012, 04:27 PM
Logan Maples
it didn't get stalled again just wont turn over randomly.. And no she will not be driving her anymore lol.
Old 10-02-2012, 06:19 PM
TRexGAWD
TRexGAWD's Avatar
Hmmm, not really sure what the problem could be.. Does it run fine when it does start?.. Does it crank slow when it doesn't start?.. How does it act when it wont start..
TRexGAWD is offline
Old 10-02-2012, 06:23 PM
UnderARock
UnderARock's Avatar
Check battery voltage yet?
UnderARock is offline
Old 10-02-2012, 07:53 PM
SR71BBMustang
SR71BBMustang's Avatar
I also had same issue randomly on my 2012 auto gt, & also have a Bama tune. I would turn key & nothing would happen, but could try key again & it would start. Problem stopped after firmware update done on the tuner & tune loaded back in.
SR71BBMustang is offline
Old 10-02-2012, 09:53 PM
CajunJosh
CajunJosh's Avatar
Could it possibly be an electronic switch on the clutch pedal going bad? Keeping the engine from starting because it thinks the pedal isn't depressed.
CajunJosh is offline
Old 10-03-2012, 12:58 AM
Logan Maples
Runs perfectly once she starts and will all day, Voltage is also fine. When I take it to the dealer tomorrow should I leave it on the Bama tune or flash it back to stock?
Old 10-03-2012, 09:33 AM
AMDanBailer
Former Sponsor
AMDanBailer's Avatar
Logan Maples,
This sounds very odd. I would definitely recommend checking what the latest firmware you downloaded on your SCT was. There's a few new SCT firmware updates out that could possibly show effects like this if it's not completed. Just give SCT a call, their customer service is great and they'll definitely get you up to date if need be. I would recommend calling them before you take the car to ford just to eliminate any possibilities first!
As far as what status you should bring the car to the dealer in. Definitely return the car to stock before you take the car in. If you don't and they for some reason flash over the tunes, not only will the tunes be useless but the device will have to be sent back to SCT be unlocked(which cost $150).
I hope this helps, other then a possible update needed, it may be just a mechanical related issue which ford will definitely have to pin point. Let me know if you have any questions or if we can be of any assistance!
-Dan
AMDanBailer is offline
Old 10-03-2012, 03:40 PM
Logan Maples
Thanks for the advice Dan will definitely be giving them a call I appreciate the help!
Old 10-06-2012, 11:33 AM
CajunJosh
CajunJosh's Avatar
Any updates?
Quick Reply: 2012 5.0 randomly won't start
