5.0L V8 Technical Discussions Any questions about the 'Coyote' engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
2012 GT Universal Joints
Old 02-21-2013, 01:48 AM
Mustang Enthusiast
Mustang Enthusiast's Avatar
Default 2012 GT Universal Joints
Does any one know if the U Joints can be lubricated on a 2012 GT. Usually most drive shafts joints have to be lubricated..I looked at the drive shaft and didn't see anywhere to lub the the U Joints. But, I could be blind thou and missed them. How about the bearing in the middle of the shaft? Probably a dumb question, but thought I would find out for sure.
I have a slight clunk every now and then coming from the drive shaft. I wish Chilton would come out with a repair guide.
Thanks
Mustang Enthusiast is offline
Old 02-21-2013, 09:48 AM
duckbubbles
duckbubbles's Avatar
It's been ages since the OEM's have made anything easily serviceable like that. Your options are to take it apart and lube it or replace the joints with after market units that have grease zerks. This was all done in the (false) belief that the less places to grease, the better.
Frank
duckbubbles is offline
Old 02-21-2013, 11:56 AM
clowe1965
clowe1965's Avatar
The clunk is normal. Drivetrain slop is always there. But no, there arent any grease points.
clowe1965 is offline
Old 02-21-2013, 05:25 PM
Mustang Enthusiast
Frank
Thanks for the information. It has been a long time since I have owned an American made car. My first car was a 1969 Cougar XR7, and every car after was a Japanese car until last year when I got my Mustang GT. I was more familiar with the old grease fittings, at least on the U joints and assumed they would still be installed on the Mustangs.
Old 02-21-2013, 05:31 PM
Mustang Enthusiast
Thank you for the information. Do you know why Ford installed a two piece drive shaft with a bearing in the middle rather than a one piece drive shaft? I was curious since you can supposedly replace the current one with a solid drive shaft with no problems. Ford Racing and other companies sell them.
Old 02-21-2013, 05:35 PM
mapitts
mapitts's Avatar
We also have to deal with a rubber mounted carrier bearing. That makes the clunk clowe1965 describe only worse. I have never been able to figure out why Ford went that way with a driveshaft so short. I am also with you on the fact that a U joint needs a shot of grease every now and then.
mapitts is offline
Old 02-21-2013, 06:22 PM
clowe1965
clowe1965's Avatar
Not sure why they went with the two piece either. My 92 ranger had a two piece as well. Might be so they can change the first portion of the shaft to accommodate the different transmission/engine configurations and save cost be only modifying a shorter shaft than the entire one. Just speculation here.
The one piece does help with the clunk, and a significant performance benefit. Also helps me sleep at night knowing I am less likely to shear my ds.
Old 02-21-2013, 07:05 PM
mapitts
mapitts's Avatar
I do know that if the carrier bearing goes out, the bearing itself cannot be replaced. It is far cheaper to go with a 1 piece aluminum DS.
mapitts is offline
Old 02-21-2013, 07:10 PM
Slowbra302
Slowbra302's Avatar
The only time I get a clunk is when I come completely off the accelerator in 6th and then I go back on after the car start engine braking..... Usually only below 2000rpm. Thought I was going crazy but it appears to be common lol
Slowbra302 is offline
Old 02-21-2013, 11:07 PM
908ssp
908ssp's Avatar
One reason for the two piece driveshaft is crash worthiness. With the stock shaft the engine can submarine under the chassis during a frontal collision with less force and therefore it is less likely to intrude into the passenger compartment.
908ssp is offline
Quick Reply: 2012 GT Universal Joints
