5.0L V8 Technical Discussions Any questions about the 'Coyote' engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
Weight reduction
Old 07-13-2013, 12:08 AM
stealth_GT
stealth_GT's Avatar
Default Weight reduction
How much of a reduction can a carbon fiber hood, carbon fiber trunk, rear seat delete, one piece aluminum driveshaft, skinnies up front, 17's in the back reduce in the 1/4 mile on a full bolt on 5.0??
stealth_GT is offline
Old 07-13-2013, 03:35 AM
draxxus131
draxxus131's Avatar
I believe the rule of thumb is to subtract a tenth of a second for almost every 100 pounds. In all honesty though, the DRIVER is the best upgrade for shaving off time.
draxxus131 is offline
Old 07-14-2013, 05:25 PM
CrzyHrs
CrzyHrs's Avatar
Agreed with Draxxus, I've heard that every 100 pounds is a tenth of a second.
CrzyHrs is offline
Old 07-14-2013, 06:53 PM
clowe1965
clowe1965's Avatar
Driveshaft is advertised as .2, I can verify. More of a piece of mind thing and get rid of some drivetrain slop. Driver mod is the best. Rotational weight counts for more than shedding dead weight, so wheels and driveshaft make up more than the 100/.10s accounts for. Not sure of what that number is though. Have you already removed the rear seat?
clowe1965 is offline
Old 07-18-2013, 10:00 AM
allenmaty
allenmaty's Avatar
That's why I'm on a mission to loose a few lbs! Better for me and the car...
allenmaty is offline
Old 07-25-2013, 01:00 PM
Shane780
Shane780's Avatar
Look into a carbon fiber driveshaft 15lbs, and tsw rotary forged wheels in the 18 inch size. 18 lbs a piece. If you had the factory 19's you would shed 12 lbs per wheel, and 30 lbs in the drive shaft. 54 lbs of rotating mass at least removed. If lighter tires were used a long with some lighter rotors even more could be removed. I'm not sure if there is a company that makes forged aluminum axles..but now im starting to get a bit extreme. Drive shaft and then rims will make the biggest difference in weight loss.
Shane780 is offline
baddog671
07-26-2016 01:20 PM
uedlose
The Racers Bench
10-01-2015 08:31 PM
jar_are_red
09-24-2015 07:03 AM
09-08-2015 11:50 AM
Quick Reply: Weight reduction
