5.0L V8 Technical Discussions Any questions about the 'Coyote' engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
Check Fuel Fill Inlet Help!
Old 10-26-2015, 09:20 AM
VickieGT
VickieGT's Avatar
Default Check Fuel Fill Inlet Help!
I let my son fuel the car yesterday and I noticed immediately that the miles left on that tank only went up to about 275.... I knew that wasn't right, since it usually goes up over 300 when I fill up.
This morning the Check Fuel Fill Inlet Alert Popped Up!
What does that mean?
VickieGT is offline
Old 10-26-2015, 09:56 AM
jz78817
jz78817's Avatar
you have the "capless" fuel filler, and it sounds like the flap may not be sealing. Ford vehicles tend to have a separate warning for a loose gas cap/flap instead of just turning on the "check engine" light.
jz78817 is offline
Old 10-26-2015, 10:05 AM
VickieGT
VickieGT's Avatar
Yes. This is capless. Car runs perfectly fine. Mileage and then that Alert. I hope it is nothing. Thank you for your response!
VickieGT is offline
Old 10-26-2015, 02:01 PM
P51C
P51C's Avatar
Keep calm and find the little funnel that is in the spare tire well for adding fuel from a can to the tank. Poke it down the fill hole a few times and then see if the light goes out.
All Mustangs 11-14 are capless cars, btw.
P51C is offline
