witch subs better performance Wise
#61
RE: witch subs better performance Wise
Preal, Seight 311, now I understand what ttocs & hiss was saying this guy does not understand you cant have both its either SPl or SQ. I guess that is one reason why I rarely post up here.
#67
ORIGINAL: 07lane40
keep in mind if you tune it that high (around 50-60 hz) you can damage the sub(s) if you play regular music. not SPL test tones. so if you get somethin burpin around 25-30 Hz on your CD player you might blow somethin. if its not a strict comp set up just tune it around 30Hz.
you can tune a single box multiple times. no need to build more boxes. take a couple days to build one quality box, and work on the tuning the next few days.
I have never heard anyone port a box intentionally to 50-60hz in a car that they drive....
If you want SPL with a little SQ go with around 35hz. If you want better SQ, the closer you get to 30 hz the better.
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
