Go Back   MustangForums.com > Ford Mustang Tech > Audio/Visual Electronics
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 08-01-2009, 09:59 AM   #1
thvoicwethin
thvoicwethin's Avatar
Vehicle: 2000 Ford Mustang
Send a message via AIM to thvoicwethin Send a message via Skype™ to thvoicwethin
Default 1600w Powerbass Amp, questions?
I just bought a 1600w amplifier. I have 2 500w 12" subwoofers that i have installed running on a 300 watt Visonik. So it's pushing about 150w to each.
The new powerbass amp (asa-600.4x) is 4 channel and puts 400w x 2, 200 x 2, and i think another 200 x 2.
NEW QUESTION:
I have the amp bridged so both subs can get 400w to each. Why is only one of the speakers producing the power?
Specs R here:
Quote:
SPECIFICATIONS:
• 4 ohm Power : 100W x 4
• 2 ohm Power : 200W x 4
• 4 ohm Mono Power : 400W x 2
• Peak Power : 1600W
• Total Harmonic Distortion : <0.05%
• Frequency Response : 20Hz - 22,000Hz
• S/N Ratio : >94 dB/W/M
• Damping Factor : >150
• Input Sensitivity : 0.5 - 4.0 volts
• Crossover Slope : 12 dB
• High-Pass Crossover Freq : 40Hz - 250Hz
• Low-Pass Crossover Freq : 40Hz - 250Hz
• Variable Subwoofer EQ : 0/+18 dB
• Subwoofer EQ Frequency : 40Hz
• Dimensions : 14.9 " x 9.3 " x 1.9 "
• Dimensions : 379mm x 238mm x 48mm
__________________
Member of NC Mustangs Group
thvoicwethin is offline   Reply With Quote
Old 08-01-2009, 06:24 PM   #2
Graeli
Graeli's Avatar
Vehicle: 2007 Ford Mustang
You wouldn't need anything to keep your battery from dying. A capacitor might be a good idea if you plan on bumpin without the car being on though. They run about 70 bucks at walmart for i think a 1600 watt one. And yeah, you should be able to hook up your front speakers as well.
__________________
Bone Stock 2007 V6 Mustang
Coming Soon - 4.10 gears, CAI/Tuner Combo, and Flowmaster dual exhaust.
Graeli is offline   Reply With Quote
Old 08-01-2009, 06:36 PM   #3
thvoicwethin
Quote:
How would i run the speakers through the amp without JUST getting the bass? I have always been confused on hooking the high-freq thing up so that it also produces the treble and mids....thanks for you help by the way.
__________________
Old 08-01-2009, 11:36 PM   #4
Graeli
Graeli's Avatar
I'm not sure. I can ask one of my friends who has his hooked like you're wanting and see what he says and get back to you. Good Luck!
__________________
Old 08-05-2009, 11:50 AM   #5
thvoicwethin
thanks!
__________________
Old 08-05-2009, 01:15 PM   #6
JayMax03
2004 Ford Mustang
My Garage
JayMax03's Avatar
Vehicle: 2004, Ford, Mustang
for a better solution do the BIG3 always if necessary high output alternator it way better than some cap... caps don't do anything but put a strain on the alternator anyway its like adding another battery to the car
__________________
2004 Smoked Gray Mustang "40th Anniversary"
Pioneer Premier Avic F90BT
(2) Cerwin Vega V-Max 12.2 subs
Cerwin Vega EXL1200D amp
Alpine MRP450 amp
Alpine 6.5 2-way coaxial speakers and component set speakers
Python 872 LE 2 Way Remote Start and Security
JayMax03 is offline   Reply With Quote
Old 08-05-2009, 06:46 PM   #7
ttocs
1994 Ford Mustang
ttocs's Avatar
welcome to the forum.
first, caps are nothing more then audio-candy. They do very little for what they cost and will never EVER keep your system bumping with the key off. That is just not what they were made for....
If you put a link to the amp and its specs then we can answer if it will do what you want it to.
__________________
http://www.cardomain.com/ride/2395420
ttocs is offline   Reply With Quote
Old 08-05-2009, 08:19 PM   #8
thvoicwethin
SPECIFICATIONS:
Also, we hooked it up today, and have it bridged so that the 400w x 2 is sent to each 500w sub, and im only getting ONE sub to produce the 400w, the other one just sits there. anybody know the reason?
__________________
Old 08-07-2009, 06:34 PM   #9
ttocs
1994 Ford Mustang
ttocs's Avatar
as long as you subs are 4 ohm woofers then you will get 400 watts per sub.
__________________
Old 08-08-2009, 10:33 AM   #10
thvoicwethin
I think i know the reason. Im not using both RCA inputs so only one speaker is producing the sounds. When a switch an RCA over to the other input, they both work, but im afraid that something will happen or ill fry it. So i need to run another set of RCAs to the HU.
Thanks all.
__________________
1600, 2000, 6004, amp, amplifier, amplifiers, amps, asa, bass, car, ford, high, mustang, power, powerbass, put, reviews, saga, watt, ways
Featured Sponsors
New Sponsors
ฉ Internet Brands, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Fordฎ is a registered trademark of the Ford Motor Company
