Go Back   MustangForums.com > Ford Mustang Tech > Audio/Visual Electronics
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-25-2009, 11:59 PM   #11
audiofrek19
Vehicle: 1997 Ford Mustang
thats probably gonna sound like crap unless you got really weak speakers. i would hook up one or two but not four thats just dumb your not getting any more power by adding more subs
audiofrek19 is offline   Reply With Quote
Old 10-27-2009, 11:35 AM   #12
msmith
1966 Ford Mustang
msmith's Avatar
Vehicle: 1966 Ford Mustang Convertible
Quote:
There is no logical reason why four woofers would "sound like crap" compared to fewer woofers.
As long as you're giving each woofer its recommended box volume, four woofers will be 3dB louder than two woofers with the same total power (four are more efficient than two). They can also handle twice the power, which would net you another 3dB.
If you're willing to give up the space, four beats two every time.
__________________
M Smith
1966 Mustang Conv.
Wimbledon White
Ivy Gold Luxury Int.
msmith is offline   Reply With Quote
Old 10-29-2009, 10:05 PM   #13
audiofrek19
i dont mean it will sound like crap. i mean if you have 4 higher powered rms rated subs and hook it up to the one amp your most likely not going to get the recomended power to each of those speakers which can either cause it to blow the speaker or not sound good. as long as the subs are getting at least the minimum power needed then it will be fine.
2ohm, 4ohm, 5001, amp, component, diagram, jl, ohm, ohms, run, setup, single, speaker, speakers, wire, wiring
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
