2010 V6 wiring questions
Old 05-27-2011, 03:46 PM
AnInsulinAddict
AnInsulinAddict's Avatar
Default 2010 V6 wiring questions
I have a 2010 V6 and I'm putting in some 12" subs. I didn't want to replace the stock stereo so I bought this to splice into the stock harness. All I need to know is what wires are the left and right speaker wires and what is positive and negative wires.
If someone had a wiring schematic that would work too.
AnInsulinAddict is offline
Old 05-28-2011, 06:10 AM
ttocs
ttocs's Avatar
not sure on the wire colors but fyi keep that as close to the deck as you can to avoid catching and then amplifying noise.
ttocs is offline
Old 05-28-2011, 05:19 PM
AnInsulinAddict
If I did use an aftermarket radio is there another face plate I could buy or would a lot of the stock one just be useless?
Old 05-29-2011, 06:36 AM
ttocs
ttocs's Avatar
a lot of the stock one? - not sure what you mean there. If you did swap out the deck you would need a kit(faceplate?) to make it fit but would not need the line out converter you bought.
ttocs is offline
force
S197 Shelby Section
10-17-2009 09:34 AM
Oli4
08-09-2009 11:22 PM
jocatch
07-23-2009 10:45 PM
Ownasaur
07-06-2009 06:03 PM
Red6
03-20-2009 01:52 PM
Quick Reply: 2010 V6 wiring questions
