Wanting to upgrade my Mach 460 system
Well I'm getting my mustang soon! 2000 V6 with the mach 460 system and the audio quality is crap. I would like to put a Kenwood unit in and remove the cd player completely. I also want to run 2 10" subs in the trunk. I've read that you have to have some kind of adapter or something to do this? I'm not sound system smart so I'm just confused as to how I can get what I want because I heard the Mach 460 already has an amp?
Cody if you are going to replace your radio and speakers too. just follow the wiring instructions for your radio. You will be eliminating the entire mach 460 system including the amps. and speakers. You will also need the plastic stereo mounting adaptor that your kenwood will mount into. that will replace the space where your mach 460 stereo used to be in the dash.
If it plays but sounds weak and tinny it could be:
wired wrong
burnt fuse for amps
the wrong harness ( only one plug )
If that was the case the stereo would still play but sound terrible.
It is playing through the tweeters and small mids.
There would be no power to the amps!
No full range, no subs, = NO BASS.
Mustangs w/mach460 can be a little confusing to hook up correctly.
wired wrong
burnt fuse for amps
if your car was in a wreck and the door replaced you may not have the Mach 460 speakers in the door, you could have wal mart brand replacements or something. Does your car have a clean title?
You should be satisfied with a correctly working mach460 system. The speakers arent crap at all and 90% of people wont be able to tell the difference between them and some fancy expensive Bose package; ESPECIALLY if you have loud exhaust.
DrunknRuckus
08-23-2015 10:05 AM
