Mach 460 drains battery dead
Old 04-26-2015, 10:52 AM
rarestamx
rarestamx's Avatar
Default Mach 460 drains battery dead
My 2001 gt convertible, Drains my battery dead in 2 days. Pulled 25 amp fuse for stereo and the draw is gone. Has anyone heard of this problem? Need to know where to start?
rarestamx is offline
Old 04-26-2015, 03:38 PM
jwog666
jwog666's Avatar
put the fuse back in and remove the radio unit, if the draw is still gone, time to replace the radio
jwog666 is offline
Old 04-26-2015, 07:14 PM
rarestamx
rarestamx's Avatar
Ok i will try that, Was not sure if it was the stereo or the amp.
Old 05-12-2015, 05:06 PM
rarestamx
rarestamx's Avatar
Pulled the radio, put the 25 amp fuse back in, Still drains the battery dead. Are the amps hot all the time, and could one be shorted out? Heard there are 3 amps, not sure. Where to start now.
Old 05-12-2015, 07:09 PM
jwog666
jwog666's Avatar
they should not be hot all the time, they should only come on when the radio is turned on. the amps are under the rear package tray, if u lay down in the trunk and look up you can see them. unplug them and check the same way you did with the radio, i beleive that there are 2
jwog666 is offline
Old 05-12-2015, 08:23 PM
rarestamx
rarestamx's Avatar
they should not be hot all the time, they should only come on when the radio is turned on. the amps are under the rear package tray, if u lay down in the trunk and look up you can see them. unplug them and check the same way you did with the radio, i believe that there are 2
Ok, will look, as it is a convertible the trunk is damp, Heard there was a third amp under the dash to power the speakers on the doors, by the side mirrors?
Just cant understand what else that 25 amp fuse would power. It is hot when there is no key turned on?
Old 05-12-2015, 08:40 PM
jwog666
jwog666's Avatar
according to the service manual there are only 2 amps, both in the rear, one runs the left and the other the right speakers for the rear, the rest of the speakers are powered by the radio itself
The coupe Mach 460 system consists of eight speakers and one subwoofer amplifier. The convertible Mach 460 system consists of eight speakers and two subwoofer amplifiers.
jwog666 is offline
jerrytubes
10-23-2015 12:11 PM
jrrhd73must
10-02-2015 09:17 PM
breaking
10-02-2015 01:27 PM
Sixer4Life
09-29-2015 07:03 PM
wraith777
09-28-2015 10:49 AM
Quick Reply: Mach 460 drains battery dead
