Stupid welding question
It has been a week or so since I practiced a little on my welding and apparently I forgot to shut off my tank the last I used it. I went to use it and turn the tank on only to find it was on and the first gauge was at zero with no pressure. I was getting really crappy welds so there was no gas coming out.
I have only practiced several times so I don't think I used toooo much gas to run it empty.
Could the tank self empty if I accidentally left the tank fully open for a week or so???
If it can, I just learned an expensive lesson.
Lynn
Lynn
Thanks, I figured as much...
I called the guy that was showing how to weld also and said the same thing.
An expensive lesson to learn.....
It was a great way to shoot my afternoon all to heck.
Lynn
Lynn
Forget about the nitrous option there are strict regulations when it comes to high pressure gas cylinders.One wrong thing and boom.A guy I used to work with got burned when an oxygen leak ignited the oil in his work clothes.He was rushed to the hospital with third degree burns.
Guys, also be sure to open the valve on the cylinder completely and don't just give it a twist when you open it. High pressure cylinders have a two seat valve due to the extreme pressure. If you don't open it all the way up and hit that second seat, it can leak around the valve stem. Been selling gas and welding supplies for 20 years and I see it all the time. Also are you sure your distributor didn't accidentally give you an empty cylinder? Might mention this when you go in for a fill, most suppliers will give you the benefit of the doubt (at least the first time).
Note- Do this on high-pressure bottles, such as the O2 welding bottle and MIG welder bottle. DO NOT open acetylene valves all the way. That's a needle valve and less than a turn usually does it.
