Prodject---My dads Pony
Old 10-13-2010, 01:31 AM
  #121
crashfab
crashfab's Avatar
So putting right along. I got the heater hoses done except hooking them up to the heater core and sealing them to the body. Waiting for the defroster duct assembly to show up--will need the extra room to install it and the heater hoses will be in the way once they are hooked to the heater core.
crashfab is offline
Old 10-13-2010, 01:36 AM
  #122
crashfab
crashfab's Avatar
Next I dug into the dash pad and getting it cleaned up to install.
One of the 4 studs that holds the pad to the metal portion of the dash. For the record they are 10 24.
I cleaned it with a toothbrush and some special cleaner we use at work. I was pretty happy with how nice it looks regarding how old it is.
crashfab is offline
Old 10-13-2010, 01:45 AM
  #123
crashfab
crashfab's Avatar
I went ahead and tore down the cluster and inspected what I could. Ya you can certainly tell its old but you can now see the guages with the lense clean,lol
So I installed the dash pad and this time with all 4 studs and all 8 screws and it fits MUCH better now than it did before. I also installed the wiper switch and new headlamp switch along with the ignition switch and cig lighter. All the bezel pieces were worked over with mothers polish--they really look nice.
I also gave this some polish love and I was impressed with how well it turned out--looks gooood.
So I threw the cluster back in along with the steering tube/steering wheel. I am getting closer and it looks sharp now. Dad is going to love this..
crashfab is offline
Old 10-13-2010, 02:46 AM
  #124
darkshadow03gt
darkshadow03gt's Avatar
You going to be doing anything to those pedals?
darkshadow03gt is offline
Old 10-13-2010, 09:57 AM
  #125
crashfab
crashfab's Avatar
Yup. Waiting for new pads...
crashfab is offline
Old 10-13-2010, 06:50 PM
  #126
hightower2011
hightower2011's Avatar
I feel like if I just sat down watching you work in your shop, my own productivity would increase 5 times.
hightower2011 is offline
Old 10-14-2010, 12:01 AM
  #127
White05GT
White05GT's Avatar
Really coming along, looks good!
White05GT is offline
Old 10-15-2010, 12:44 AM
  #128
crashfab
crashfab's Avatar
Thanks guys
crashfab is offline
Old 10-15-2010, 12:52 AM
  #129
crashfab
crashfab's Avatar
So earlier in the thread I had mentioned I had no idea the switch in the glove box was for the 4 way flashers(was just resting in it). Well after that bit of reasearch I "thought" the switch was mounted to the metal portion of the glove box lip. Well I was digging thru a few boxes of misc stuff my dad had gotten when he bought the car and I found this.
From my understanding and reading 66' was the one year where the switch is hardwired to the harness and replacements were a blade style switch. Well I found this bezel with a blade style switch on it so there is a spare. The other thing I finally figured out is the fact the switch bezel actually mounts to the carboard glovebox insert--odd. In any case when I get the replacement insert I can install it correctly now.
crashfab is offline
Old 10-15-2010, 12:57 AM
  #130
crashfab
crashfab's Avatar
So the last couple nights have been slow going--mainly because I am taking my time to make sure its as good as I can make it--plus this small stuff just takes time.
So This was harder than I thought--trying to replace the E-brake handle. The handle it held on by a pin. Well after some work I found if I pushed the pin all the way in--and then drilled a small portion of the end off I could remove the handle. Once it was off there was a shole in the ebrake rod that let me force the pin back out. In any case thats DONE!
This also took some time mainly to make sure and not scratch the newly painted dash. I also dissassembled the whole thing and polished it up. There was a spare on in the box of stuff so I swapped parts as need be and made a VERY nice assembly out of it. I also hooked both heat and temp cables up. Once we get the new defrost parts I can hook that up. But it turned out pretty nice.
crashfab is offline
Quick Reply: Prodject---My dads Pony
