View Poll Results: Which one?
4 barrel
100.00%
2 barrel
0%
Voters: 5. You may not vote on this poll
Carb options
I'll start looking. Found one 500 for 150 that was said to be in good working order so possibly no rebuild. Just seems kinda high.
The edelbrock is only 6 years old, with less than 100 hours of run time on it (yard project). Kinda strange it would go out of wack like this. Sometimes if i blip the trottle it will come back to idle smoothly for a minute or two, so I'm guessing that is the problem. Should I switch the vacuum advance over to the timed port instead of the manifold port perhaps?
Well it was the wires causing the skipping. No vacuum leaks, and I switched the dizzy over to the timed port. Idling smoothly at 600. Now onto the massive drivetrain slop I've got going on.
jwog666
12-27-2021 08:09 PM
bradleyb
11-27-2015 07:50 PM
Daddys Girls GTs
09-14-2015 08:46 PM
