T5 conversion
Old 01-08-2014, 01:48 PM
my68ride
my68ride's Avatar
Default T5 conversion
I'm in the process of changing my wiring harness, but before I get too far with the install, I thought I would remove the automatic brake pedal assembly on my 68 hardtop. How the heck does it come off? It looks like there is two lock nuts on a sleeve, but I can't seem to move them. Is there a special tool, or does the whole bracket assembly that bolts to the firewall and holds the brake booster and master cylinder have to come off? Doesn't look like that is possible.
my68ride is offline
Old 01-09-2014, 10:24 AM
69mach1377
69mach1377's Avatar
Or you can trim off the excess pedal material to match the rubber pad and call it done...
69mach1377 is offline
Old 01-28-2014, 10:17 PM
my68ride
my68ride's Avatar
Thanks, I have pedal assembly off and I will trim and use it with the new clutch pedal.
my68ride is offline
Old 01-29-2014, 01:13 PM
69mach1377
69mach1377's Avatar
Not sure why it had to come off to trim it...
Old 01-30-2014, 08:04 AM
my68ride
my68ride's Avatar
It didn't. But I got a wrench jammed on the brake pedal bolt and couldn't get it out and besides I had to remove the brake booster to drill hole and install clutch cable bracket for the clutch. Seems I can always find the difficult way!
my68ride is offline
HRnB
GT350 S550 Tech
12-18-2015 09:35 AM
11-10-2015 11:39 AM
DCole24
09-11-2015 10:50 AM
YoungStangsMan
09-05-2015 07:01 PM
Quick Reply: T5 conversion
