Horn won't honk
Old 09-02-2014, 07:46 AM
Seadog
Seadog's Avatar
Default Horn won't honk
Actually, one of them works and the other doesn't. I checked the wiring and that is not the problem.
So, wondering if any of you have tried repairing a horn? I will take it apart and look, maybe just a connection that needs soldering.
If any of you have replaced a horn with a new one, what brand is a good one?
Thanks!
Seadog is offline
Old 09-02-2014, 09:11 AM
bop11
bop11's Avatar
There is a high and a low horn. The two notes make the horn more attention getting. First make sure the horn has a really good ground. Many times the ground connection rusts up. The horn is just a diaphragm that vibrates and when it does it opens and closes a set of contacts. The contacts can pit and corrode. Some horns have a nut on them to change the note. They are so cheap that repair is a waste of time. An OEM is $51 a replica is only $37. Or Pep boys probably has some even cheaper.
bop11 is offline
BOB ROME
07-26-2023 01:54 PM
lincolnshibuya
12-08-2015 04:37 PM
ChampInSD
10-02-2015 04:55 AM
14gt_Track
10-01-2015 02:47 PM
09-29-2015 03:23 PM
Quick Reply: Horn won't honk
