1965 headers problems
Old 11-08-2014, 11:56 PM
mike1965
mike1965's Avatar
Default 1965 headers problems
I recently purchased a 65 coupe. The car has a 302 which is obviously not stock. The headers do not allow the last spark plug to be removed to be changed. Im thinking of replacing the headers. Does anyone know what will fit and not cost a fortune?
mike1965 is offline
Old 11-09-2014, 10:16 AM
barnett468
barnett468's Avatar
heed to know exactly what heads you have . . if they are gt40p heads and the old style dart windsor heads are problematic. . . hedman elite shorty's are good . . you can also but spark plugs that around 5/16" shorter if that will help.
barnett468 is offline
Old 11-09-2014, 12:03 PM
mike1965
mike1965's Avatar
The problem is that the back of the header covers a small part of the area that I need in order to get the socket over the plug. Im thinking if I can grind off the width of about two sheets of paper then I will have the needed clearance.
mike1965 is offline
Old 11-10-2014, 01:19 PM
barnett468
barnett468's Avatar
ok, do that then or use a thin wall socket.
SSG Steggy
3.7L V6 Technical Discussions
11-05-2015 03:09 PM
Luke9222
10-22-2015 11:55 PM
Brian Emmer
09-09-2015 02:50 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
Luke9222
09-04-2015 06:46 AM
Quick Reply: 1965 headers problems
