holley 4bbl 600cfm carb
i have a 66 coupe .. when i bought it, it had a 2bbl carb and intake on it however i changed it to a 4bbl intake and carb. the problem is, ever since i made the conversion my engine has been missing terribly. i pulled one of the spark plugs out and it had carbon all over it so it was definitly not firing but could the 600 cfm carb be to much and if so what 4bbl carb should i put on it...is it running a to rich of a fuel/air mixture. thanks for all replies
it could be,,,,spark plugs,,,,wires,,,,or carb..change plugs first and see thats the cheapest way ,,unless you need wires anyway are they old???could be carb,,blown power valve???just work your way up to the carb..let us know your results...
RE: holley 4bbl 600cfm carb
I'm looking at a 670CFM for my 65. The street avenger Holley carb. thats for 300-400 HP. I have mods and stuff so I know i'm over 300. But I think that 600 you have would be okay..
ORIGINAL: 65CoupRacer935
Carbon buildup does not necessarily mean it is not firing. An easy way to check that is to remove the plug. Put the spark plug wire back on the plug and hold it with an insulated pair of pliers. Then roll the motor over..look for the spark. If you have no spark or a weak spark, do the same thing with the wire coming off the coil to the center post on the distributor cap. Grab it with an insulated pair of pliers, and hold it about an inch above the center post. of the distributor. You should see a spark (be careful not to get to close to a ground cause it will ZAP you). If again you see a weak spark your coil may be going away.
Ron
Ron
bradleyb
11-27-2015 07:50 PM
uberstang1
09-20-2015 06:42 PM
Daddys Girls GTs
09-14-2015 08:46 PM
