4 speed question
RE: 4 speed question
you may be able to fit it in. personally, try calling mustangsplus or mustang depot and see if they know or have a kit for it.
also, depending on the overall size of the trans, the transmission tunnel will have to be modified (cut out, raised and re-welded).
also check the FAQ section
ORIGINAL: Colorado_Mustang
Is that a side loader or top loader? They did make a 4sp toploader in that era that was od in 4th. The toploaders from that era aren't nearly as strong as the older models, either.
yeah imma go with a t-5 from modern drive line. they are going to help me build up a tranny so it can take the horsepower from my 302.
i also spoke with moderndriveline about the modifications to the tunnel, they told me i dont need to modify anything cuz the 68-70 had huge tunnels and tko's can fit up there. i just need to open up the shifter hole and buy the tranny mount conversion.
musnicki
09-23-2015 07:11 AM
