Car runs great but turns off rough - help!
RE: Car runs great but turns off rough - help!
Do you have an after market igntion such as MSD or Mallory. Sometimes people forget to install the little DIODE that comes with the kit. The DIODE prevents current from traveling to the igntion system when the car is shut off. I had to do the same thing with my car.
Matt
Matt
Well that looks like a coil to me. Check to see if ther are any other boxes in the engien compartment that say mallory. Go to this website, which has the instructinos that i have for my ssytem. In there on the 4th page ther is the diagram of the DIODE. I hope this helps. http://go.mrgasket.com/pdf/6852M_6853M.pdf
Feel free to ask any questions. If it turns out that you dont have an after market system that the use of a DIODE is not needed, your timing is probably to far advance.
Matt
Matt
Timing too far advance and/or carb idle mixture too rich
Here's a check...turn the car off with it still in drive (you know...slightly different routine.....instead of...brake, come to stop, put in park, turn off key.....brake, come to stop, turn of key, put in park). If it doesn't do ka-chung ka-chung....dial back the timing a couple degrees.
When its warm....like when you run to store, go in and rent a movie, and then come back out to start the car, does it crank slow? This is another indication of too much initial advance
