varnish question?
varnish question?
well i keep hearing from mechanics that after a car has been sitting old gas can turn to tarnish and everthing needs to be taken out and cleaned and boiled , is their a easier way around this do they make a tarnish cleaner yet that u can put in th gas tank to kill any buildup?
RE: tarnish question?
The carb may need a little more work, especially if it was allowed to dry out. I've used fresh gas to restore some fuel systems enough to get a car to run. The F250 in my sig sat for 10 years and I was able to get it to run with 5 gallons of fresh gas. The Ford 2V is a tough/simple carb. Don't put too much gas in the tank, however, if something did get plugged up, you'll just be making the tank that much harder to remove.
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
