hard starting
hard starting
Hi. have a 66 289 2v that is very hard to start. I have rebuilt the carb, new fuel filter. I took off the pcv line, and it started right up, but ran at a very high rpm. I have ordered a new valve and line, and was wondering if this might be the cure. If not on to the distributer. Any ideas? Thanks
RE: hard starting
My vote is for some electrical issue. Even with your carb slightly out of adjustment it will generally start. I would check timing, points and rotor. Make sure and clean your point with a fine sandpaper to remove any bumps or dimples.
Dragonus18
09-09-2015 01:21 AM
