American Thunder Exhaust Kit
Old 09-06-2006, 08:33 PM
michaeldoggrell
michaeldoggrell's Avatar
Default American Thunder Exhaust Kit
Ok guys
I've installed the Hedman headers onto the 289 Block. Now i'm facing problems with the H-pipe. They dont match with the ends of the headers ?
Anyone else had this experience ? how did you solve this ?
Mike
michaeldoggrell is offline
Old 08-07-2010, 08:59 AM
Tx-Ranger
Tx-Ranger's Avatar
Hi,
i´ve the same problem. i´m sure that someone solved that prob.
Can anyone help me?
Tx-Ranger is offline
Old 08-07-2010, 09:44 AM
2+2GT
2+2GT's Avatar
I use a stock H-pipe, and cut it to connect to the reducers. If the outlet is badly mis-matched, you'll need a short straight pipe welded at both ends. A small difference can usually be cured by forcing the header left or right to line up. Most headers are mild steel, and should respond to this treatment.
This is a stock H-pipe attached to original Tri-Y's.
2+2GT is offline
carid
07-08-2016 09:55 AM
10-05-2015 06:07 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
TimeLord101
09-04-2015 09:27 AM
09-01-2015 08:16 PM
Quick Reply: American Thunder Exhaust Kit
