carb spacer
RE: carb spacer
ORIGINAL: Colorado_Mustang
You are better off with a spacer. If you want to check, drive around without it for a while and see how you like it.
ORIGINAL: atomsk680
what, you dont need a spacer? i have one, my dads, soon to be my brothers 71, has one. my friends vette and camaro has them, i thought it was just omething all engines have[&:]
my spacer is good, im gunna keep it
RE: carb spacer
ORIGINAL: Brandontyler65
nope they are an aftermarket thing second the plastic ones are supposed to be a bit better cause they are less prone to warp
RE: carb spacer
i was going to say....i thought all fords came with carb spacers...i just bought a truck with a 400ci and a 600 holley and there wasnt a carb spacer....my dad saw that and about shat himself.
RE: carb spacer
ORIGINAL: randy78045
I dont know if it's true or not, but i read somewhere that spacers shift the torque range sumhow... [:-]
By the way, I have a phenolic spacer if sumone wants one cheap...
RE: carb spacer
ORIGINAL: valley firearms
I am interested. What kind is it and will it work for a Holley w/ Performer?
RE: carb spacer
Different engines respond differently to each carb spacer. there is no real "rule of thumb" or guideline for what does what. four hole, three hole, open, tapered, stepped, swirled, 1/2",1", 2".. they all do different things. Some engines that have a somewhat restrictive intake will respond to a taller one, it adds plenumn volume. All of them will benefit from a cooler intake charge, but you can get that without a spacer too. the only way to really tell what the engine likes as far as design, size or even if it needs one, is at the track or on a dyno.
if you cant get a quantifiable repeatable result from something, you dont know if it has improved or degraded your peformance. So just driving around with one on may do something and it may not. I have only one engine that liked a spacer, and it was a 1050 Dominator carb on a Victor intake with 467 ci under it. The rest ran essentially the same and all the spacer did was creat a hood clearance issue.
had a buddys 72 chevy Luv pickup go .4 faster in the 1/4 by installing a 2" open spacer and a lighter spring in the secondaries. it went from a 13.1 to a 12.7 on a hotter day. Not sure if it was the carb or the spacer that helped it. I left to go back in the USAF shortly after we ran it so no further testing on my part.
RE: carb spacer
Thanks Randy. Since jroseman started the thread and may be looking for one, I will give him first shot at yours since he started this. If he doesn't want it then I will be interested. The stud configuration is the same as the Demon. As long as it doesn't have the small primary and larger secondary like the Quadrajet spacer has it should be fine. Let me know if he does not contact you within a few days.
It is one inch.... an as for the holly, i wanna say yes cuz demon an holly are the same in lots of ways... if you can measure the studs... or go off a gasket or sumthin...
RE: carb spacer
bradleyb
11-27-2015 07:50 PM
Daddys Girls GTs
09-14-2015 08:46 PM
jaiidutch
09-14-2015 10:29 AM
