427 small block stroker
I am looking to buy a 351 windsor motor for my 1967 mustang. Is there any sort of stroker kit or budget build to make a 427 small block? If so, what needs to be installed (carb, intake, etc...) to compensate for the increased displacement the motor will have? Thanks.
RE: 427 small block stroker
there's alot of those 427w kits out there, but it makes the stroke longer than the bore. this is not always recomended by engine builders if you want a powerfull/reving car engine.. a nice 408 kit is what i would recomend, and that will give you a 4.03" bore and a 4.00" stroke.
427
http://cgi.ebay.com/ebaymotors/ws/eB...tem=7975948135
408
http://cgi.ebay.com/ebaymotors/ws/eB...m=190037627801
392/393
http://cgi.ebay.com/ebaymotors/ws/eB...m=280034613173
427
408
392/393
I work for an engine builder we can build that 427 for you for around $5,800 depending on what you want to do with it. WE normally use dart or afr heads forged eagle crank H beam rods and ether Malhe or JE forged pistons. All engines are balanced, blueprinted and Dyno tested and tuned. the dyno sheet you get is from your engine. If you want a new dart block we can go as high as a 460 ci engine. here is a link to the ebay store it will give you base prices and also a link to the web site. If you rather build it yourself we can also sell you the kit to do it with but I'm not sure of the price the 347 kits go for about $890 I believe.
http://stores.ebay.com/T-AND-L-ENGINES
http://tandlengines.com
daltron
04-28-2016 08:10 PM
