need pictures
Old 10-26-2006, 05:07 PM
fastback311
fastback311's Avatar
Default need pictures
I need a photo of the lifter valley, i need a shot of the hole where you oil the cam gear if anybody can post a pic i need to compare it to my hole
fastback311 is offline
Old 10-26-2006, 05:20 PM
Soaring
I ♥ Acer
Soaring's Avatar
Default RE: need pictures
ORIGINAL: fastback311
You owe me a cup of coffee. I just spewed mine all over the monitor.
Soaring is offline
Old 10-26-2006, 05:22 PM
fastback311
you know what i mean my rough hole
Old 10-26-2006, 05:24 PM
fastback311
hay soaring do you know if the hole is really supposed to be there, i am getting alot no answers, they say i should replace my block
Old 10-26-2006, 05:42 PM
Soaring
I ♥ Acer
Soaring's Avatar
Snap a shot of it, and let's have a look. If DodgeStang says it is supposed to be there so oil gets to your cam, then you can bet your booty it is supposed to be there. I want to see exactly what hole you are talking about.
Soaring is offline
Old 10-26-2006, 05:48 PM
THUMPIN455
THUMPIN455's Avatar
and again here... its supposed to be there. Looks strange, but its there for a reason..
If I can get the inttake off one of my 302s I will post a pic of it for you. just might pull the one from the Cougar tonight.. might.
THUMPIN455 is offline
Old 10-26-2006, 05:55 PM
Soaring
I ♥ Acer
Soaring's Avatar
Now, there are two of the smartest guys we have on this forum saying it is supposed to be there. DS and Thumpin have been there, done that. So, trust them for accurate information. Now that you have that problem solved and you don't have to replace the block, what are your next steps?
Soaring is offline
Old 10-26-2006, 05:58 PM
fastback311
thanks guys i dont know much about engines so i will trust you i have to show this forum to my friend he says it not supposed to be there but what do chevy guys really know[&:][&:]
Old 10-26-2006, 06:02 PM
THUMPIN455
THUMPIN455's Avatar
tell your chevy friend I have a 468 with 350 rods and 400 4 barrel heads on it.. The heads have 2.11 intakes, 1.77 exhaust valves, and a factory air gap manifold, its all stock parts with nothing custom. He will say something like no way, never could be.. or something similar..
then tell him I have a stock 71 small block head that factory flows 340cfm@.600 lift... he will call BS again...
Old 10-26-2006, 06:05 PM
fastback311
I am tearing down the engine blind i have never attempted this feat before i just took off the oil pan and almost had a heartattack, there is so much stuff under it should i pull off the pistons before the crank
Quick Reply: need pictures
