Help! No oil pressure!
RE: Help! No oil pressure!
Install a real gauge that has numbers. Factory gauges without numbers are not accurate.
ORIGINAL: thunderize
I have a 66 with a 289 auto. Where should the gauge read for proper oil pressure on these cars? Mine is sitting towards the low side. What is the best way to check the actual oil pressure? Thanks
ORIGINAL: 05 Cayuse
Rmodel65, I'll check out the plug suggestion. What does this plug do? If the plug was left out, wouldn't oil be pumping out all over the place?
no its under the intake
ccdguy
09-19-2015 05:20 PM
