brake questions
RE: brake questions
The best way to do drum brakes is to raise both sides and remove both wheels and drums but then only take one side at a time apart that way if you have a question all you have to do is walk around to the other side which will be a mirror image of the side you are working on
RE: brake questions
yeah, i kinda messed that all up, i didnt take pics, and toke off both of my fronts at the same time......
i replaced my brake lines so my MC is completely dry-what should i do about that?
also, i was just messing with my parts, and my adjuster thingies dont fit on my drums, they're all the right size-i measured them......really wierd
thanks for all the help!
RE: brake questions
If it were mine, I would take the MC out and bench bleed it. That way the bleeding process will go faster. If you run into trouble and need a picture, I will take off my drum and snap a pic for you.
09-08-2015 11:50 AM
mungodrums
Suspension
09-07-2015 07:22 PM
