Door tag rivits install
My door tag was missing so I order a replacement from Mustangs Plus (you give them the code numbers and they make an an exact replica!). I also purchased the two rivits that connect the tag in the exisitng home. My question is how do you install the rivits - do you take a nail punch and hammer them in (I don;t want to damage the metal surrounding the two holes). Do you need a special tool? Can you press them in by hand?
Thanks
Thanks
RE: Door tag rivits install
Just for you big boy, I went out into my shop and took some pics of how a pop rivet gun works. Basically, all you have to do is drill a hole in the metal, insert the rivet in the hole and pull the trigger.
[IMG]local://upfiles/10034/1D4D8B6501F14DCBB04325A4E04ED944.jpg[/IMG]
[IMG]local://upfiles/10034/6B397A1551B64B9D95DF0AFAB8B84D55.jpg[/IMG]
[IMG]local://upfiles/10034/2D9F436EE9224B21A6F78B64DAC6B9F0.jpg[/IMG]
ORIGINAL: 67t5ponycoupe
Here is a pic of what they look like. Just tap them in. It doesn't take much and they will go right in.
[IMG]local://upfiles/27838/E195EB228D03465DA9D44481D1C515FD.jpg[/IMG]
[IMG]local://upfiles/10034/57EA8E58AA2E42CD82F335C1A5C93DD5.jpg[/IMG]
