Ignition Switch Removal
How do you take out the igniton switch of a 1969 coupe? I am really getting frustrated. Any help would much be appreciated and if you have a manual with a diagram of it that would help too seeing as how its hard to see the darn thing.
RE: Ignition Switch Removal
Place the key into the switch. Then insert a paper clip into the small hole directly to the right and below the key. By rotating the key toward the accessory position and pulling out out on the key, the tumbler can be removed. Remove the bezel, unplug the switch leads and the switch can be removed. It took me a few times trying this procedure before the switch would come out.
jwog666
12-27-2021 08:09 PM
bradleyb
11-27-2015 07:50 PM
