i have a edlebrock carb and was wondering if anyone had advice on the pcv hose the goes from the pcv valve in the valve cover to carb if theres a good way to make it look clean i can find a hose thats right
I just used 3/8" fuel line, Im sure theres a way to make it look clean, if you get elbows and what not. it depends on where the pcv valve sits on your valve cover.
-P.
Edlebrock prob sell a base plate with the inlet nub. Other wise, you could try an old ford 4bbl plate. The hose is still available in Motorcraft . Check cj pony parts.
