Export Brace & Monte Carlo Bar - OPINIONS
RE: Export Brace & Monte Carlo Bar - OPINIONS
IMO the export brace is a great upgrade to that two piece bracing they used. The Monte Carlo bar is a nice add on but not needed. (specaily if you're trying to look as original as possible) If not, then might as well throw that in also. It can only help.
I put the MC bar on mine, and will eventually get the Export brace. Beefed up suspension and disc brakes are also in the plans. I noticed some improvement in the stiffness of the front end after I put the MC bar on, but I think they are both needed.
I know that the pair really made the Shelbys handle great in corners. The export brace was a hefty item on them, the Monte Carlo bar was fairly straight forward. I had a modified Monte Carlo bar on mine to clear the air filter on the 2 Holleys.
ORIGINAL: unit91
What's your opinion on these two add-ons?
