getting a tach?>..
Old 01-08-2007, 12:52 AM
ADRIAN1
ADRIAN1's Avatar
Default getting a tach?>..
should i get a 8 rpm tach or a 10 rpm tach?
where do most 289 redline at?
ADRIAN1 is offline
Old 01-08-2007, 01:04 AM
EmperorOfChicken
EmperorOfChicken's Avatar
Default RE: getting a tach?>..
gunna stop pulling at about 5000 rpm, 8k is PLENTY with mods you might redline some where in 6k.
EmperorOfChicken is offline
Old 01-08-2007, 01:16 AM
JamesW
Moderator
JamesW's Avatar
That's like asking do I need a 160 or 200 mph speedometer.....
It really doesn't matter....
JamesW is offline
Old 01-08-2007, 03:23 AM
Colorado_Mustang
Colorado_Mustang's Avatar
Most idle at 800 rpm or so and top out somewhere before 6000 rpm. Therefore, a 10 rpm tach would be way too low. Best would be an 8000 rpm tach.
Colorado_Mustang is offline
Old 01-08-2007, 03:29 AM
atomsk680
atomsk680's Avatar
unless you like the high RPM's, i bought a 8k and cant wait to install it
atomsk680 is offline
Old 01-08-2007, 03:45 AM
groho
groho's Avatar
speaking of tachs, how does the dash pod look on the 64-66, or do you prefer just mounting it on the steering column?
groho is offline
Old 01-08-2007, 04:24 AM
Colorado_Mustang
Get the factory looking pack on the steering column.
Old 01-08-2007, 02:53 PM
65mojoe
65mojoe's Avatar
when i first got my tach, i asked the same question. There are a couple reasons why I went with the 8k tach:
1) even with a pretty heavily modded 289, you're not going to spin anything above 7k (and even thats optimistic)
2) if you've ever seen a car with a 10k tach on it that can't even spin close to that amount, you'll notice that the movement is almost unnoticeable (i.e. during normal driving between 1500-3000 rpm, the needle is SOO low on the tach face, that it just looks retarded)
As far as mounting the tach, I would discourage mounting it directly to the dash pad unless you fabricate some sort of metal bracket for it to seat on. Drilling into the foam padding will, overtime, make the pad warp and/or crack. I've seen some slick setups were the tack is mounted, centered on the tranny hump just underneath the ash/coin tray.
65mojoe is offline
Old 01-08-2007, 07:06 PM
MidNite27
MidNite27's Avatar
^if u can get ur motor over 8k rpm's, you should be able to afford a new tach later down the road. Just go with 8
MidNite27 is offline
Old 01-08-2007, 07:09 PM
Bulldog66
Bulldog66's Avatar
ORIGINAL: Colorado_Mustang
I sooo want a rally pack, however, at 4-500 bucks, I just can't bring myself to get it.... yet. Maybe after all my other projects are done.
Bulldog66 is offline
Quick Reply: getting a tach?>..
