6 Cyl Conversion
6 Cyl Conversion
I have a 67 coupe with a 200 in it, I am going to beef up the suspention, will i need new control arms or just springs? Then replace the spindles to a 5 lug along with disc brakes. will the auto tranny work with a 351 or simmular? Is there anything im missing?
RE: 6 Cyl Conversion
Sure, that C4 tranny will work behind a 351. In addition to the whole front suspension, you will need a new rear endthough.We have some articles written about the swap up in theFAQ section right here on the classic section.
if you are changing the spindles to v8. on a 65-66 i know you need to change the steering as well. inner outer tie rods, centerlink, idlerarm, and pitman arm. not sure if that is the case for the 67. i just finished doing the complete conversion if you have any questions let me know. the SSbrakes conversion was a cinch. you'll have to change some things on the c4 to make it work as well, flywheel, bell housing, torque converter. rear end has to be changed out too as soaring said
HRnB
GT350 S550 Tech
12-18-2015 09:35 AM
11-10-2015 11:39 AM
Matt's 95 Stang
10-05-2015 07:16 AM
