Brake Conversion Question
Anyone who has done a Granada disc brake swap have a suggestion on this. I am putting the spindles, power booster, and discs on my 68 mustang. I noticed that the power booster has 4 bolts going through the firewall. Is there a template or suggestion for drilling the holes? As they say in cutting, measure twice and cut once. I just want to know if there is a more easy way to install this? Also, I understand that I may also need a brake line conversion kit from the hose to the brake line if I am using Granada calipers as well. Who has the best prices on these? Any help would be appreciated. Thanks.
RE: Brake Conversion Question
JamesW, thanks. Good site with lots of information for me. I think I am not going to use the power booster from the Granada but rather go purchase the new M/C you mentioned. That way I have no redrilling at all and can use the stock holes. I took the proportioning valve off the Granada so this should still work with the new M/C.
Thanks again for the help.
mungodrums
Suspension
09-07-2015 07:22 PM
