650dp fluding
650dp fluding
I am having problems with my car fluding, it only dose it when i get on itand it willdie or even when im crusing some times it will just die ,and to start it you have to let it set for about 10 min or so and when you finalleystartit it smells like raw gas and a lot of white smoke comes out of both mufflers, (and its not the head gasket ) any ideas? or a good site that explainsthe 650 dp ?
RE: 650dp fluding
Only takes about 2 hours to pull it down and go through it. Try adjusting first along with all the rest of the obvious stuff ( vacume lines, recent tune, etc ).
20 bucks for a kit and 2 hours = problem solved if it's indeed a carb issue.
