600 double pumper??
Old 11-11-2007, 12:26 AM
smbikes
smbikes's Avatar
Default 600 double pumper??
Well i have tried a few carbs and none really made me happy , frist i had a 650DP witha a profourm main body and it made awsome power when u kicked it but rideingaround it flooed like carzy , so i got a 670 street avanger and it dose awsome when you are just rideing around and cranks good but i hate the way the 2nd came in and done really have a strong bottom end , so i was thinking a brand new stock 600 dp would do me good? or sould i just try to rework my 650DP?
my motor mods are
302 ci bored 40 over,10.5:1 total compression ratio; comp cams XE274HR cam .555/.565 lift; 1.6 roller rockers Scorpion; victor jr intake with 1" phenolic spacer; procomp aluminum heads (ported and polished) with 2.055I, 1.60E valves
smbikes is offline
Old 11-11-2007, 12:54 AM
aode08
aode08's Avatar
Default RE: 600 double pumper??
What are your supplying fuel to?
The car has a 302 making near 500 hp, dont think stock can touch.
aode08 is offline
Old 11-11-2007, 01:13 AM
WhiteWindsor
WhiteWindsor's Avatar
You might know this, but a true dp is a mechanical secondary. Just because it has a place for two fuel lines do's not make i a double pumper. The 670 is a vacuum sec. If the other was a true dp, it sounds like your sec. were out of adjustment. I have been fooling with my hp 750 for awhile trying to tune and adjust, that may be all it needed.
WhiteWindsor is offline
Old 11-11-2007, 06:26 AM
Joel5.0
Joel5.0's Avatar
You already have the 650DP..... it's a matter of reworking it and fixing the part-throttle flooding (check those floats, or replace them) and tune it.
Joel5.0 is offline
Old 11-11-2007, 08:45 AM
smbikes
smbikes's Avatar
i have a a/f wideband tuner and the readings from thedp is all over the carts . 1 min it running rich at 10:8 or so the the next it jumps tovery lean at 17:1, and i have no clue y
smbikes is offline
Old 11-11-2007, 09:18 AM
AdderMk2
Banned
AdderMk2's Avatar
this is again... why fuel injection owns all
AdderMk2 is offline
Boostaddict
2.3L Eco-Boost Tech
11-24-2015 06:11 AM
Bokeo
10-10-2015 08:28 PM
ChampInSD
10-02-2015 04:55 AM
DreadPirateRoberts
09-26-2015 02:11 PM
Quick Reply: 600 double pumper??
